B-service
Torben
Tilmeldt: 21. apr 2009, 12:22
B-service
Indlæg af Torben »
Jeg har en 220 CDI, aut. fra 2004, kørt 170.000.
Jeg skal have foretaget B-service inden længe.
Jeg har forstået at der kan være penge at spare hos
Mercedes i Tyskland, men det har hidtil ikke været mig mulig
at få at hvide, hvormeget der er at spare.
Er der mon nogen af jer, som har et tip - 10% - 25% eller mere?
På forhånd tak for svar.
Torben
Et B service er primært visuel kontrol, samt olie og filterskift.
Lej en lift på gds værksted, olie, filter og pakning, pollenfilter max kr. 1500 ialt og 1-1½ times arbejde.
madsen12
Tilmeldt: 30. apr 2009, 09:48
Indlæg af madsen12 »
Et B service er det der kaldes et lille service ?
Og kan man selv resette sin service "lampe" på en C200 (W203)
A SERVICE
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
Der er hvad man "får", og ja de fleste servicedisp. kan man selv resette.
madsen12
En der ved hvordan jeg resset min servicedisp. på en C220 K (w203)
How to reset service interval
1. Put key in and turn it to the #2 position....do NOT start the car!
2. Scroll the menu button until the vehicle mileage shows
3. Use the "up and down" button until the "wrenches" show
4. Press and HOLD the trip reset button in for 10 seconds and then release it
5. Press and HOLD the trip reset button in for another 3 seconds and release it
6. Your vehicle service indicator should now be reset.
